Selecting 4 wheel drive on its own.
01 Feb 2021 18:04 #232399
by bryn
Selecting 4 wheel drive on its own. was created by bryn
I drive a 2011 Jimny which has been fine with no problems. Of late when I start up the car from cold it will select 4 wheel drive without me pushing the selector switch. I then have no problems taking it out of 4x4 once I notice the issue and I can select 4x4 when I wish with no problems.
I have checked the wiring underneath to the transfer box with nothing obviuous showing and have looked at the 4x4 stuff in the engine bay again with nothing obvious. I do use 4x4 on a regular basis.
My only conclusion at present is to get a new/second hand switch, so any pointers would be much appreciated.
bryn
bryn
- Thank you received: 1996
01 Feb 2021 18:17 #232400
Replied by Lambert on topic Selecting 4 wheel drive on its own.
Have you gone through it with contact spray for water ingress?
- Roger Fairclough
- Thank you received: 225
01 Feb 2021 19:47 #232402
by Roger Fairclough
Replied by Roger Fairclough on topic Selecting 4 wheel drive on its own.
I am a little worried when you say that you have no problem taking it out of 4x4 when you notice the issue. Can you tell us how far you might have driven before you noticed, on what sort of surface you were on at the time and whether you noticed a bang or a shudder when you did switch the 4x4 off.
Roger
Roger
01 Feb 2021 20:32 #232404
by bryn
Replied by bryn on topic Selecting 4 wheel drive on its own.
It happens a soon as I start the car up. No movement..
Bryn
Bryn
01 Feb 2021 22:51 #232414
Replied by yakuza on topic Selecting 4 wheel drive on its own.
Has the car had any modifications done? Like electrical in the dash or stereo or central lock or ignition? Anything under the car around the transfer box?
Often strange electric flaws comes from mishaps from fiddling or bad ground.
02 Feb 2021 05:56 #232418
Also if you can. Disconnect the battery overnight to let it reboot the controller.
Time to create page: 0.204 seconds
