Gear Lever - A bit fiddly to get into gear (Gen 4)
- Groenewald
I will do the following this afternoon:
* Make sure there's no obstruction when I depress the clutch
* Check the clutch adjustment - first figure out where and then how
I got my Jimny with 7500km on the clock. When do they usually do the first fluids change?
Another question for the GEN 4 owners:
When you depress the clutch fully, how far from the bottom should the clutch start to engage?
Fluid changes detailed in the owner's manual. Normal driving is like 40k kms for gearbox oil change. I did mine at around 10k kms . TC has been changed twice for me, once with new chain installed and once when the gearbox oil was changed.Groenewald wrote: Thanks for all the suggestions!
Have seen a video of gearbox oil change at 20k kms and it was black.
Keeping the car a while and think 40k kms is way too long before a change.
crash486 JB74W
- Roger Fairclough
- Thank you received: 225
Roger
- Groenewald
He said it feels fine. I also compared it to another one they had on the floor, and it felt rather similar.
Mind you, I tend to compare it to our Rav4's gear shifting - but the Rav is on about 330K km now....
- Thank you received: 1997
