Drive shaft from an auto on a manual?
- Thank you received: 504
10 Dec 2020 07:22 #230812
Drive shaft from an auto on a manual? was created by yakuza
They are the same i guess?
Mine is sqeeking so I am buying a used rear drive shaft from a 2010 auto. It should fit my 2005 manual right?
- Thank you received: 1875
10 Dec 2020 08:04 #230813
Replied by Lambert on topic Drive shaft from an auto on a manual?
Would it not be easier to rebuild the existing one with new joints?
10 Dec 2020 08:35 #230814
Replied by yakuza on topic Drive shaft from an auto on a manual?
Yes, when it's out of the car. But then it is faster just to put the used one on. So little time, so cold garage, so lazy mechanic.. Very little difference in cost if the used shaft is ok.
10 Dec 2020 08:39 - 10 Dec 2020 08:42 #230815
I see now the half shafts in the front axle are called drive shafts too so i might have done a linguistic blunder here? Lost in translation?
The shaft from the transfer case to the rear axle is called what?
Propeller shaft?
(very confusing when I design propeller shafts for ships and those are a bit different with a propeller attached in the rear end..)
Propeller shaft?
Last edit: 10 Dec 2020 08:42 by yakuza.
- Thank you received: 683
10 Dec 2020 10:30 #230819
Replied by jackonlyjack on topic Drive shaft from an auto on a manual?
Yes it's a rear propeller shaft (prop shaft) here in the UK
10 Dec 2020 10:45 #230820
Thanks!
But is it the same shaft on manual and auto?
Time to create page: 0.768 seconds
