2din radio in 2006 jimny (convertor ? )
- Borre
01 Dec 2020 14:55 #230554
by Borre
2din radio in 2006 jimny (convertor ? ) was created by Borre
hello, I am try in to put a 2din radio (Pioneer DEH-S720BT 2DIN radio)
into my 2006 jimny.
after removing the plastic case which contains a tray and a 1din radio space.
there is enough room for the radio. but not for the metal case that came with radio.
i have about 105mm of height (and 185 width) in my jimny.
the metal casing of the radio has a height of 112mm and width of 182mm
so the height wont fit. but the metal casing is much bigger than the radio it self.
(radio has a height of 100mm)
so I think I need a different radio casing.
I found this one.
www.amazon.nl/Audioproject-A145-universe...6576038&sr=8-1-fkmr1
which has a outside size of 182 x 103, that could it my jimny.
But has some extra space on left and right.
And how could I mount this into the jimny?
Is there some plastic casing like this that could fit a 2din radio?
(instead of 1din and a tray, if I remove the tray, the space is to narrow for a radio.)
some more images:
into my 2006 jimny.
I found this one.
some more images:
- Thank you received: 1998
01 Dec 2020 19:37 #230568
Replied by Lambert on topic 2din radio in 2006 jimny (convertor ? )
The standard sort of not quite double din units are held in with a bracket bolted directly to the chassis of the radio and the four holes in the dash that you have your tray fastened to. I don't know if these bracket are available separately or what their part numbers are but it might be worth having a word with Martin in the forum shop to see what he is able to supply.
- Thank you received: 667
01 Dec 2020 22:59 #230578
Replied by DrRobin on topic 2din radio in 2006 jimny (convertor ? )
My 2011 Jimny was fitted with the standard radio which was double DIN, but with rounded corners, apparently this is the unusual to have rounded corners on most cars. I found an Xtrons Android double DIN unit which was a perfect fit.
However, your Jimny seems to have a single DIN unit with tray underneath, I am not sure if this was standard for your year or if it was a mod?
Google Jimny double DIN radio to see what will fit.
