G16 Swap with Baleno harness and ECU, Tach and Speedo NC
  • Jim Jim
29 Oct 2020 12:55 #229549 by Jim Jim
We have to maybe do a manual switch control for the 4WD system since the Balneo is not 4WD, so the ECU will not take any input orders from the 4WD module :)
Have to track down a throttle position sensor low signal fault code too then it will be working perfectly.
  • Jim Jim
29 Oct 2020 14:01 #229553 by Jim Jim
Here are the pics Safari, from these you can easily understand what I did.
I also came up with a different idea for the right side engine mounting modification, pics of that too below.
  • Jim Jim
29 Oct 2020 14:05 - 29 Oct 2020 14:11 #229554 by Jim Jim
Completed left and right side mods are done on the gear box side.
Last edit: 29 Oct 2020 14:11 by Jim Jim.
10 Nov 2020 14:51 #229902 by safari
tks very interesting photos
if u worry u die if u dont worry u still die so why worry
Time to create page: 0.174 seconds
