A strange sound when climbing the ramp
- avehbiaslanturk
Topic Author
- Junior Member
- Thank you received: 2
" First of all, I apologize for my poor English. "
I own a 2009 stock Jimny at 136.000 km. Also it has an automatic transmission.
My problem is this : Such a sound comes when I climb the steep slopes at especially low speeds with my car.
What could be the problem? What should I check? Thank you so much.
Video Link : drive.google.com/file/d/1JHTMcqTJS0zYBVf...vrI/view?usp=sharing
- Roger Fairclough
- Thank you received: 225
Roger
- avehbiaslanturk
Topic Author
- Junior Member
Roger Fairclough wrote: The track on your video would appear to be tarmac and, without having info. on the degree of the slope, probably be drivable in high range.If you have selected low range and the hubs are locked then you may be experiencing axle wind up. This will promote extra pressure in the transfer box and that means noise. If you need low range with hubs locked periodically drive over a surface that will allow wheels to spin. This will relieve pressure in the transfer box. Also bear in mind that using the transfer box is inherently noisy.
Roger
Sorry for the missing information and thank you for the answer. In the video, my car was in 2WD mode. I rarely use 4WD and 4WD-L modes. If I use it, I only use it on slippery surfaces.
- Roger Fairclough
Roger
- Andy2640
Still havnt got mine resolved yet.
- avehbiaslanturk
Topic Author
- Junior Member
Andy2640 wrote: Oh crikey! I thought you had the dreaded "Mirco-grind" for a second there. But alas...its a gen 3.
Sorry, I don't quite understand what you said.
