Chassis mount fabrication
  • AdDeTa
24 Jul 2020 19:21 #225592 by AdDeTa
Replied by AdDeTa on topic Chassis mount fabrication
Lambert wrote: Welcome to the forum. The process is replicated by using a thing called a dimple die. They're either pressed hydraulically or by using a heavy nut and bolt. The die will be expensive for a one off but a body shop should be able to do you some to weld in cheaply enough.
Thanks Lambert, have seen your posts in a few threads in my relatively short time here. Seeing as I’ve been re-assured to my thinking that they aren’t a must have then I’m more than faithful to trust my own work with it otherwise your suggestion would’ve been what I went for. Thanks.
Adam
Time to create page: 0.153 seconds
