Clutch judder when hot and prop question.
21 Jul 2020 07:46 #225417 by kirkynut
Sounds like the clutch to me, not the cable. The cables are cheap though and easy to change, so it might not be the end of the world to change it as a process of elimination but I'm sure it's the clutch.
The following user(s) said Thank You: Dal
21 Jul 2020 20:17 #225439 by Busta
The propshafts don't need to be bolted on a specific way, but they will vibrate if the ends are not correctly aligned.
Obviously this doesn't apply to the rear prop which has a CV joint at one end.
Time to create page: 0.467 seconds
