2001 Jimny rough idle when warm (suspect misfire)
- Radupuh
08 Jul 2020 15:22 - 08 Jul 2020 15:39 #224687
by Radupuh
2001 Jimny rough idle when warm (suspect misfire) was created by Radupuh
Hi everyone,
I've owned a 2001 Jimny (soft top, G13BB engine) for a while now (barely had time to use it though due to the COVID pandemic) and I've been struggling with an issue for a while now: once the engine gets warm, it begins to have a rough idle, where the car shudders for a split second, the rpm drops a bit and then drops back to normal. The issue is completely absent when the engine is cold at idle or when the engine is running at higher rpm.
The car didn't have this issue when I bought it, then I had it serviced (oil change, timing belt change, general maintenance etc.) including replacing the spark plugs with some the previous owner had bought but never got the chance to install (Febi Bistein, my mechanic warned me he didn't like the brand) and the issue started to occur shortly afterward.
I first tried to have a look at the sensor at the top back of the engine (replaced it with one from a friend's car) and it didn't help.
Then I had the spark plugs changed again with some NGKs and the issue appeared to be gone. Drove the car for about 300 km (including refueling once) without the issue, Then suddenly, just after I refueled it a 2nd time, the issue was back.
What I plan to try next:
- borrow the spark plug cables from my friend and see if that helps in any way
- try cleaning the throttle
Any other ideas what I could be looking at?
Thanks a lot in advance.
Edit: Bad gasoline on the 2nd refueling seems unlikely, as another Jimny refueled in the same place at the same time and had no issues with it.
Last edit: 08 Jul 2020 15:39 by Radupuh.
- CC Baxter
08 Jul 2020 17:17 #224694
by CC Baxter
Replied by CC Baxter on topic 2001 Jimny rough idle when warm (suspect misfire)
Try the idle air control valve in the throttle body, a good clean might help. Chris
08 Jul 2020 21:49 #224701
by Scimike
Replied by Scimike on topic 2001 Jimny rough idle when warm (suspect misfire)
Hi,
Yep swap the coil packs as they can be the cause of many running issues then it's clean the IAC valve as Chris states. The IAC stepper valve only comes into play when the engine is warm and can stick.
Good luck
Mike
Good luck
Mike
- Radupuh
21 Aug 2020 19:52 #227119
by Radupuh
Replied by Radupuh on topic 2001 Jimny rough idle when warm (suspect misfire)
Took longer than anticipated, but finally got to the bottom of it: it was the coil packs.
22 Aug 2020 08:05 #227150
by kirkynut
Replied by kirkynut on topic 2001 Jimny rough idle when warm (suspect misfire)
Well done in getting to the bottom of it. It's harder on the single cam engines as you can't get a code reader as easily as the twin cams due to them not being OBD2 compliant (On board diagnostics).
Having read this for the first time I was thinking coil pack as they can behave differently with heat.
Febi-bilstein is a good brand generally but I've not heard of them doing electrical stuff or spark plugs before, so they've branched into a new market and your mechanic was likely nervous about them as cars can be sensitive to spark plugs and brands.
Keep them as spares though as they are a quality brand used by manufacturer.
Time to create page: 0.961 seconds
