07 Jimny power loss
  • SHAFT666
02 Jul 2020 16:11 #224393 by SHAFT666
07 Jimny power loss was created by SHAFT666
as above, suddenly have a loss of power. Running smoothly, seems to have more of a roar from the engine but very sluggish. Any ideas much appreciated
02 Jul 2020 16:44 #224396 by kirkynut
Replied by kirkynut on topic 07 Jimny power loss
I'm guessing there's no engine management light or codes stored?
Could be a blocked cat if so.
The following user(s) said Thank You: SHAFT666
  • SHAFT666
02 Jul 2020 16:48 #224398 by SHAFT666
Replied by SHAFT666 on topic 07 Jimny power loss
Had a brand new cat only 6 months ago. No engine warning light but that doesn't even light up when I start the jeep so I'm guessing that's been disabled by a previous owner. Local garage plugged it in and no codes stored.
02 Jul 2020 22:29 #224417 by bryn
Replied by bryn on topic 07 Jimny power loss
Coils and leads. Similar thing happened to me on an 07 jimny, initially thought it was a fuel problem but got a second hand set of leads/coils from a scrappy and it sorted it.
bryn
PS if you search on my threads you’ll find my original post.
  • SHAFT666
02 Jul 2020 23:10 #224419 by SHAFT666
Had a coil pack blow on me just after I bought it, replaced both coil packs, leads, plugs etc with brand new parts only 6 months ago.
Apart from the sudden lack of power the engine is running great, no misfiring or any other sign of it running rough.
03 Jul 2020 04:04 #224424 by Lambert
Replied by Lambert on topic 07 Jimny power loss
Check that the brake calipers are free to slide, they can bind on which makes the difference in a Jimny.
