Jimny will crank over but not start.
- JimnyCal
15 May 2020 14:45 #222275
by JimnyCal
Jimny will crank over but not start. was created by JimnyCal
I've just replaced the thermostat housing on the car, topped up with Coolant. Car will crank over fine, will not start up for whatever reason. I've checked everything over, everything is connected fine and back in place as it was. It started up fine revs died down, went to give it gas engine stopped, now it won't start again. I'm at my wits end here.
2003 M13A Jimny
2003 M13A Jimny
- Thank you received: 1999
16 May 2020 05:22 #222294
Replied by Lambert on topic Jimny will crank over but not start.
Did you take the inlet manifold off to do the thermostat?
17 May 2020 09:32 #222378
by kirkynut
So as it was fine before you disturbed it, check your work on how well you put it back together. Is that where you are going with this Lambert.
There could be a big air leak?
Replied by kirkynut on topic Jimny will crank over but not start.
Lambert wrote: Did you take the inlet manifold off to do the thermostat?
17 May 2020 12:37 #222398
Or a vacuum leak or missed loom connector. Alternatively if something impacted one of the sensors?
Time to create page: 0.220 seconds
