Re:rear axle breather
24 Mar 2020 09:02 #220208 by safari
rear axle breather was created by safari
yesterday i tried to drill the breather valve of the axle for the extention pipes unfortionatly the drill bit broke and fell in the housing :( :(
tried to empty the oil but nothing came out . I would like to know if the inside breather is plastic or metal or any idea how to take them off without removing the whole diff
TKS
if u worry u die if u dont worry u still die so why worry
24 Mar 2020 09:29 #220209 by Max Headroom
Replied by Max Headroom on topic rear axle breather
Strong magnet?
24 Mar 2020 14:42 #220215 by sniper
Replied by sniper on topic rear axle breather
Try to fish it out but be sure to compare the broken drill piece against the remaining bit, then you will know if you have all of it.
If not it is a strip down and wash out.....
sniper
  • X8GGY
24 Mar 2020 14:51 - 24 Mar 2020 14:52 #220217 by X8GGY
Replied by X8GGY on topic rear axle breather
You shouldn't need to drill it?
You just pull the cap off and then tap the inside of the remaining tube on top of the axle?...
Last edit: 24 Mar 2020 14:52 by X8GGY.
24 Mar 2020 19:44 #220228 by safari
Replied by safari on topic rear axle breather
So when you take the cap off what is under or what shall you find
24 Mar 2020 19:56 #220229 by mlines
Replied by mlines on topic rear axle breather
This is what is under the cap
Time to create page: 0.454 seconds
