Mislaid My Fuel Pump relay
  • gc1066
22 Mar 2020 19:23 #220157 by gc1066
Mislaid My Fuel Pump relay was created by gc1066
Rather embarrassingly as part of my rebuild I carefully removed my fuel pump relay and put it in a safe place....unfortunately I now cannot remember where that is!!
Just looking to get a replacement at sensible money which for some reason I seem unable to do.
Can someone tell me if I can use a generic 4 pin relay like this please:
Relay on eBay
22 Mar 2020 20:05 - 22 Mar 2020 20:31 #220159 by Scimike
Replied by Scimike on topic Mislaid My Fuel Pump relay
I doubt the standard 40a relay you have shown is what you want.
Fuel pump relays normally require a pulse signal to indicate the engine is running, when the pulse is removed they cut out and stop the fuel pump. It's a crash safety system to stop fuel being pumped to an engine that is not running. That's why they are expensive for what they are.
Not 100% sure it applies to the Jimny and just going off "fuel pump relay" description for my comment.
Unfortunately I don't have any electrical drawings to hand in order to take a look. If no one confirms before I get to them I'll take a look for you. Just in case it makes any difference what year is your Jimny?
Last edit: 22 Mar 2020 20:31 by Scimike.
22 Mar 2020 21:36 #220162 by Scimike
Just had a look, not sure now. The ECU provides an earth for the relay coil, so it may not be a "clever" fuel pump relay as I previously described. My only concern is that as it's driven directly from the ECU, if the coil load of the generic relay is too high it could damage the ECU.
So I am still going to play it safe and say get the correct relay, don't use the generic one.
People are breaking Jimnys on here, so can't see it being difficult to get a secondhand one.
Sorry I can't help you further, someone may have a better idea and sure they will be along shortly.
All the best
Mike
  • gc1066
23 Mar 2020 09:14 #220181 by gc1066
Replied by gc1066 on topic Mislaid My Fuel Pump relay
OK, thanks for the input. Given that I'm isolating courtesy of this virus malarkey I shall take this opportunity to tidy the garage and see if I can locate my (apparently very) safe storage location.
Failing that I will invest some dosh.
Cheers
Graham
24 Mar 2020 14:11 #220213 by j999pre
Replied by j999pre on topic Mislaid My Fuel Pump relay
I probably have a standard Jimny fuel pump relay in my garage
Grey pick up Jimny
