Gen 4 - Under body Protection
23 Feb 2020 17:45 #218950
by wjamieson
Gen 4 - Under body Protection was created by wjamieson
What's folks thought on under body protection? Quite a lot now available for the Gen4 and quite keen to install most if not all but concerned about weight. The strength of the Jimny is the fact that it is lightweight and agile. Would/does installing the various guards and rock slider materially change the agility of the car and what about ground clearance?
- Andy2640
23 Feb 2020 19:10 #218953
by Andy2640
Replied by Andy2640 on topic Gen 4 - Under body Protection
You ask a good question, I too am about to get some underbody kit. I wanyed to know how much the jimnybits diff gaurds add to the ground clearance. Are they a tight fit etc.
2 diff gaurds, fuel filter, transfer case is the main bits i want. Jimnybits rocksliders are very weighty though, and i always remember martin saying how adding bits and kit just made his jimny a heavy lumbering slug lol.
I too would like some advice here too.
- Thank you received: 1871
23 Feb 2020 19:49 #218956
Replied by Lambert on topic Gen 4 - Under body Protection
Guards have a place which is primarily directed by the local terrain. Up here it is very rocky and the opportunity to smack something delicate on something hard is quite high. In places with mud guards tend to be a liability for acting like ploughs and getting compacted with goo. At last year's meeting I was still pulling lumps of dried mud out a month later! As to the lack of clearance yes it does reduce it it has to but if it's well designed it should act as a skid and just glide over the obstructions, if it's badly designed it will act as a grappling hook and be hateful.
I have dragged all my guards over various parts of the country and I honestly believe I would have cracked my transfer case by now and that would be a lot more expensive than a guard and considerably more inconvenient than getting a bit stuck.
That said many people don't bother and never do any lasting damage.
- Thank you received: 683
23 Feb 2020 20:09 - 23 Feb 2020 20:10 #218958
Replied by jackonlyjack on topic Gen 4 - Under body Protection
My gen3 running radius guards bashed these hard = must have
front shock guards adds strength
petrol tank guard some good gouges in it = must have
front diff guard took some abuse but does loose you about half inch of clearance
i will be removing mine this summer.I think the diff will take the abuse without it
i don't have transfer guard as i run sj transfer in a cradle made from 5mm steel
Last edit: 23 Feb 2020 20:10 by jackonlyjack.
- Grima
23 Feb 2020 20:10 #218959
by Grima
Replied by Grima on topic Gen 4 - Under body Protection
I don't do much off road but where I go is not nice. transfer guard & fuel filter are priority. damage to these areas = long walk home.
Question... is there any reason not to cut off that stupid front tie down point (recovery point) If you fit the bumper recovery bracket on Jimnybits??
23 Feb 2020 20:14 #218960
But radius arm guards are a must have imo
when i made my rear recovery points i cut original tie downs off
No reason at all to keep the tie down pointGrima wrote: I don't do much off road but where I go is not nice. transfer guard & fuel filter are priority. damage to these areas = long walk home.
Time to create page: 0.681 seconds
