Clutch Cable sticking
- wilt
04 Feb 2020 19:41 #218049
by wilt
Clutch Cable sticking was created by wilt
Hi all newbie here just bought a second hand Jimny 56 Plate with111600 miles on the Clock I've found when driving & depressing the Clutch Pedal it depresses & disengages the the Clutch but then there's about another inch of travel,any ideas?
Keith
Keith
04 Feb 2020 19:58 #218050
by gv42
Replied by gv42 on topic Clutch Cable sticking
A JIMNY WELCOME
The following user(s) said Thank You: wilt
04 Feb 2020 21:39 #218056
by Scimike
Replied by Scimike on topic Clutch Cable sticking
Hi Keith, welcome to Jimny ownership and the forum.
I am not 100% sure if you actually have a problem (or I don't understand), I tend to go with if it works there is nothing wrong with it.
That said the clutch cable / pedal can be adjusted via a plastic bolt on the gearbox end of the cable, usually tight to get moving, but once free can be turned by hand.
You should have 10 - 20mm of free movement in the pedal before you feel an increase in resistance, this is the point at which you actually start to lift the clutch. It's best done by hand to feel for this point, if you feel nothing or it's greater than the above spec it needs adjustment.
If you can't get this within the limits of the adjuster then it's possible you cable has stretched too much or you clutch is on its last legs, but go with the cable adjustment etc first.
But then if it's working just drive and enjoy!
Mike
Mike
- Max Headroom
- Banned
- Thank you received: 217
04 Feb 2020 21:53 - 04 Feb 2020 21:53 #218059
by Max Headroom
Replied by Max Headroom on topic Clutch Cable sticking
A Big
Jimny welcome to the forums Keith from the Cotswold Hills
Last edit: 04 Feb 2020 21:53 by Max Headroom.
- Thank you received: 1989
05 Feb 2020 05:24 #218064
Replied by Lambert on topic Clutch Cable sticking
Welcome to the forum. Agree with checking cable adjustments but it sounds about right?
- wilt
05 Feb 2020 20:34 #218085
by wilt
Replied by wilt on topic Clutch Cable sticking
Thanks Mike for the info I'm guessing probably the Clutch is at its limit it's not the smoothest when depressing the pedal but then I've been used to the Hydraulic type.Do you know how easy it is to drop the Gearbox & replace the Clutch if need be?
Keith
Keith
