Oil leak at rear of engine and flickering oil light on idle
- AWG81
28 Jan 2020 08:37 #217760
by AWG81
Oil leak at rear of engine and flickering oil light on idle was created by AWG81
Hi all, I recently acquired a 2000 1.3 Jimny and have just discovered an oil leak at the rear of the engine (amongst other problems) - the cam cover gasket looks fine and the leak seems to be coming from the lower of the two “bits” on the back of the engine and it’s dripping down onto the bell housing. It looks just like a plate with 2 bolts holding it on but it’s difficult to see exactly what’s going on down there - can anyone shed any light on what this is and how I can fix the leak? The oil light is also flickering occasionally on idle but I guess if I have a leak then oil pressure will be a touch low causing the light to come on?
Thanks in advance!
Thanks in advance!
- Max Headroom
- Banned
- Thank you received: 217
28 Jan 2020 09:02 #217761
by Max Headroom
Replied by Max Headroom on topic Oil leak at rear of engine and flickering oil light on idle
Sounds like access is a problem and in any case this needs a proper fix, but a temporary trick I've done on leaky joints is to thoroughly degrease the area. particularly around the edges of the joint and apply several coats of clear engine lacquer - of course this isn't ideal and you may not have access anyway.
I don't know where it will be but there must be an oil pressure switch somewhere that puts the light on - consider a faulty pressure switch or wiring - but be cautious about that in case the pressure really is low; its just another thing to check
- AWG81
28 Jan 2020 16:46 #217776
by AWG81
Replied by AWG81 on topic Oil leak at rear of engine and flickering oil light on idle
Thanks for the reply - on further inspection I think the leak might be coming from the upper of the two parts at the back of the engine. Cam end cover?
30 Jan 2020 08:24 #217837
by kirkynut
Replied by kirkynut on topic Oil leak at rear of engine and flickering oil light on idle
Do a bit of Googling to find your oil pressure sensor and replace it asap. I've not had cause to look for it before.
It's impossible to say where your leak is without looking at it.
You have checked the oil level haven't you? I'm not trying to be funny but you never know!
Time to create page: 0.196 seconds
