Different tires front and back, am I risking anything?
- Radupuh
24 Jan 2020 15:04 #217649
by Radupuh
Different tires front and back, am I risking anything? was created by Radupuh
Hello,
I'm the happy owner of a 2000 Cabrio Jimny for about a week and I've started working on getting it into top shape. Apart from the various small repairs/maintenance works on my to do list, there's something that slightly worries me: the car has different tires (front and back). According to the previous owner, he had a nasty tire puncture that 'killed' one of his rear tires, so he bought 2 new ones, and turned the remaining rear tire into a spare (he had none before).
This left him (and me) with 2 Bridgestone Dueler tires on the front, and 2 Michelin Latitude on the rear. They're both the same size, just different brand and dot.
Now I definitely plan to get a new set of tires, but a bit down the road (a few months).l, hence my question: am I risking anything if I'm using the car like this for now?
- Thank you received: 1876
24 Jan 2020 16:16 #217653
Replied by Lambert on topic Different tires front and back, am I risking anything?
Not at all. I have previously had infinity on the back axle and Bridgestone on the front and it was fine. What you don't want is vastly different tyre patterns on the same axle. The main advantage is that the Jimny is normally rwd not permanent 4x4 so different tyres are not a problem at either end.
- Max Headroom
- Banned
- Thank you received: 217
24 Jan 2020 18:35 - 24 Jan 2020 18:37 #217658
by Max Headroom
Replied by Max Headroom on topic Different tires front and back, am I risking anything?
Yep dont mix tyres on the same axle. Also...
Always put the best tyres (least worn) on the back whether its front wheel drive four wheel drive or rear wheel drive.
Some old school tyre fitters are saying the best tyres go on the driving wheels, but this is not so.
Explanation here
Explanation here
Last edit: 24 Jan 2020 18:37 by Max Headroom.
25 Jan 2020 06:29 #217665
by kirkynut
Replied by kirkynut on topic Different tires front and back, am I risking anything?
As said above it's fine.
The Jimny is rear wheel drive unless you engage 4wd. Then you should be on a low grip surface anyway, so any difference between the front and rear tyre diameter should allow any wind up to spin out through the tyres not gripping.
The Jimny has no centre diff to allow the front and rear axles to rotate at different speeds you see, so it must only be put in 4wd on low grip surfaces.
- Radupuh
25 Jan 2020 14:48 #217680
by Radupuh
Replied by Radupuh on topic Different tires front and back, am I risking anything?
That s good to hear, thanks everyone for the answers.
25 Jan 2020 21:10 #217690
by gv42
Replied by gv42 on topic Different tires front and back, am I risking anything?
can you have the front are 195-80-15 and rear are 205-70-15,??
Time to create page: 0.470 seconds
