1 Inch Spring Spacers?
02 Jan 2020 19:13 #216946 by Soeley
Replied by Soeley on topic 1 Inch Spring Spacers?
Thanks Riccy, that is certainly something to consider. I'd not really given DIY guards a thought ;)
02 Jan 2020 23:38 #216949 by jackonlyjack
Replied by jackonlyjack on topic 1 Inch Spring Spacers?
Has Riccy says ;)
Also you will need a thick M12 (around 4mm) washer to put on the outside of original mount
In between your guard and mount
03 Jan 2020 17:07 #216962 by yakuza
Replied by yakuza on topic 1 Inch Spring Spacers?
jackonlyjack wrote: I like my 1" body lift
Makes it easier to wash mud from round body mounts.
Also makes it easier to change gearbox oil.
Yes it's not an easy job to do but worth it in my opinion.
I liked my Bodylift as well on my SJ, should be same pro's and cons for the jimny.
Made room for rocksliders at the sides without loosing clearance.
Made room for lifting the transfer box and exhaust (and gas tank) so I could have a flat belly skid plate.
most important made room for 2" bigger tires together with some cutting of the fenders.
