Very high fuel consumption (2l/10km) G13BB
  • Iaitoo
16 Jul 2019 15:53 #211129 by Iaitoo
Replied by Iaitoo on topic Very high fuel consumption (2l/10km) G13BB
I will double check the brakes. But it recently had new brake hoses, and a new caliper on one side with new glide pins on the other side. It is not pulling and feels nippy enough.
  • mickt
22 Jul 2019 09:10 #211387 by mickt
Replied by mickt on topic Very high fuel consumption (2l/10km) G13BB
Woman driver and worn clutch anyway, bad combination!
  • Iaitoo
22 Jul 2019 17:51 #211407 by Iaitoo
Probably :P
I drove it again this weekend and the clutch is slipping sometimes. Waiting for a new one :) I have also changed the bosch spark plugs I bought from the bigjimny store. They have a big tip. The new Brisk ones I bought have fine wire tips. And seems like that did something. It does not struggle at low revs anymore!
23 Jul 2019 22:59 #211436 by yakuza
Good the plugs helped. If it is still thirsty, Could it be bad gas on the island? Condensation in it?
Air filter?
Low tire pressure?
Leaky intake manifold?
Stuck or bad dynamo/ac/power steering/something?
  • mickt
24 Jul 2019 20:15 #211449 by mickt
Check fuel pipe run to and from engine to tank as they get a lot of crud at the tank end and they might have pin hole leak!
  • Iaitoo
28 Jul 2019 14:17 #211589 by Iaitoo
yakuza wrote: Good the plugs helped. If it is still thirsty, Could it be bad gas on the island? Condensation in it?
Air filter?
Low tire pressure?
They dont sell fuel there, I have to bring it from the city. Its all new and good :) Will have to see how it is now, but I have used it a bit and the the fuel gauge isnt going down so fast that I can see it anymore. Tire pressure is not bad I think. Could be a leaky manifold or something stuck. Will check if all pullys are spinning! Thanks :)
