Flashing 4WD Light Confusion
- Thank you received: 226
08 Jul 2019 03:41 #210758
by zukebob
Replied by zukebob on topic Flashing 4WD Light Confusion
Had the opportunity to reconnect the vacuum system while capping the hub lines only. The short story is it appears that 2014 and later Jimnys require the vacuum system connected when using manual hubs. The method of fooling the controller by shorting the vacuum switch doesn't work. There has obviously been a change to the controller architecture so that it is receiving additional input. With the switch reconnected and the lines capped at the hubs, the transfer operates as normal.
I hope someone ultimately benefits from my stubborn stupidity. I will be creating a separate thread since most people searching the forum for this information will likely do it with AVM or 'manual hubs' as keywords. I will also post the updated transfer case document in that thread.
Thanks again Lambert.
- Thank you received: 1885
08 Jul 2019 04:13 #210761
Replied by Lambert on topic Flashing 4WD Light Confusion
Welcome as ever. Glad you have sorted it out.
Time to create page: 0.133 seconds
