Fuel tank removal procedure
www.bigjimny.com/mediawiki/index.php?tit...val_and_installation
Kirkynut, I agree that it is not that much of a project, but it should neither be taken so lightly. For example, not taking care to return the propeller shaft to its original mounting position can lead to its vibrations.
I have added some of your remarks into the wiki guide as well.
Kirkynut - my thing with the grounding relates to idiot proofing/liability issues with numpties trying to follow the guide :laugh: Im an electrician so deal with explosive atmospheres now and then, which is very different. Get it wrong and boom!
- Mr CC
no hoses are disconnected so safe enough to use a battery drill at the moment. any suggestions are welcome.
will also have a competent friend present and an extinguisher,
- Mr CC
going to clean the filter once he pumps out the tank.
more seized bolts, got three moving, after 2 nights wd40 and tapping with a hammer.
just perseverence for the other 3. should take another couple of days.
Mr CC wrote: absolute pain of a job but got it done. time to clean off then hammerite the floor underneath, and then stone chip.
Such fun eh!
Why do we do this stuff?
Bosanek wrote: Here is the new wiki guide:
Just two comments
I was always planning to do this with my car as well just did not have the balls to actually do it
How to identify the right position of shaft if no mark has been taken before removal? Or like in a situation when someone fits new/aftermarket shafts?
TrailMaster 2" lift kit
ORE transfer box HD brackets
T-Max split charge system
Flo-Flex castor polybushes
Kumho KL71 tyres
AVM manual hubs
ORA radius arm guards
Push-fit breathers
