Re:Engine sometimes runs on 3 cylinders ??
- Ram1976
19 Jun 2019 00:39 #210120
by Ram1976
Engine sometimes runs on 3 cylinders ?? was created by Ram1976
Looking for some advice please lads ,
I’ve got a 2002 Jimny and recently it’s been running quite rough but only occasionally , at first I thought it was crap in the fuel tank as it did it when it was really low , sounded like it was running on 3 cylinders stuttering etc etc , so I put some fuel in her and gave her a run and it seemed to clear said problem , she had been sitting for a week and that was as soon as I fired her up , now she seems to be ok when starting but after a while at really low revs she stutters until higher up the Rev range and then she is fine ?! ... any ideas would be greatly appreciated .
Thanks
Ramsay
Thanks
Ramsay
- Thank you received: 1881
19 Jun 2019 04:40 #210124
Replied by Lambert on topic Engine sometimes runs on 3 cylinders ??
Welcome to the forum. When was the car last serviced? I would start with a thorough service if it wasn't recent and do oil and filters and plugs. If it persists then plug wires and coils. Simple things first.
- Ram1976
19 Jun 2019 08:13 #210127
by Ram1976
Replied by Ram1976 on topic Engine sometimes runs on 3 cylinders ??
Thanks for the reply , it had an oil and filter change last October not sure if the plugs got changed , will give that a try . Thank you
19 Jun 2019 08:25 - 19 Jun 2019 08:27 #210128
Replied by yakuza on topic Engine sometimes runs on 3 cylinders ??
I problem persist after changing the plugs, try this:
Try removing the lid over the coils and run it without. might cool the coils down so they do not heat up so fast. When it studders, try pulling off the plug wire at the far rear. use gloves or pliers so you do not get shocked. If the car stops you unplugged a working coil/plug.
If the car runs just as bad when you unplug you found the faulty one, then change your coil.
I got a new coil off ebay at approx. 30£
Cost less then your average garage would charge just to find the fault.
Last edit: 19 Jun 2019 08:27 by yakuza.
The following user(s) said Thank You: Ram1976
19 Jun 2019 09:46 #210129
Replied by mlines on topic Re:Engine sometimes runs on 3 cylinders ??
The ignition system is "wasted spark" so one coil feeds two cylinders at a time. Therefore a coil issue tends to take out both.
19 Jun 2019 10:06 - 19 Jun 2019 10:08 #210130
I know but my lazyness prevented me from starting to ask wether it runs on two or three.
The difference is not obvious unless you start to unhook the plug leads, and unhooking the one with coil on it is not so straight forward
Edit; Might try to listen for, or in the darkness try to look for, a grounding spark from the plug wire as well, and/or try to change the plug wires.
Replied by yakuza on topic Re:Engine sometimes runs on 3 cylinders ??
mlines wrote: The ignition system is "wasted spark" so one coil feeds two cylinders at a time. Therefore a coil issue tends to take out both.
Last edit: 19 Jun 2019 10:08 by yakuza.
Time to create page: 0.960 seconds
