Adding POIs (speed cameras etc,) to gen 4 SatNav
- Thank you received: 624
05 Jun 2019 18:39 #209675
by facade
Adding POIs (speed cameras etc,) to gen 4 SatNav was created by facade
After some experimenting, here is where I have got to.
You need
A USB memory stick
Some POI data
A PC
First off, your memory stick has to have a directory called "myPOIs"
Inside that directory, goes anther directory called "myPOIWarnings"
POI files are CSV (comma separated variables) files, that you can download or make your own.
The format is
Longitude,Latitude,Name,Address,Telephone
Longitude is decimal degrees EAST of Greenwich, and Latitude is decimal degrees North of the equator.
Whatever is in the Name field is the name of the POI, and will appear in the POI search near me listing
e.g.
If it is a warning you get a beep and the message"approaching Name" I'm not sure if the address & telephone will appear too, the pop-up is big enough. An icon appears on the map after the warning is triggered, there must be an inbuilt icon for a GATSO, as a speed camera icon appears on mine.
To trigger a warning, the warning files MUST be called
myPOIWarnings_*******.csv
You can have more than one, but they must start with myPOIWarnings_
For a normal POI, I think you can call the file what you like, mine is myPOIs.csv and it goes inside the "myPOIs" folder.
Anyway, you just put the USB stick into the socket under the aircon, and it prompts to load data, then if you get a progress bar, it has worked.
You can then search your POIs and POI warnings using the "navigate to" menus.
Where to get the data from?
There are some free resources about, you need to download in GARMIN CSV OR Nissan Connect format. TOM TOM uses a different format, that you can convert but best to get one that doesn't need it.
You can switch Google earth into decimal degrees format and just plonk the pointer where you want and read the co-ordinates off the status bar, or place a marker where you want and the co-ordinates appear in the properties box. You can even save a few points then export them as "my places" then import into your CSV file.
I was hoping that having a 24x24 or 22x22 bmp image with the exact same name as the CSV file would load a custom icon, but it doesn't on mine
You need
A USB memory stick
Some POI data
A PC
The format is
e.g.
- Thank you received: 1875
06 Jun 2019 05:23 #209691
Replied by Lambert on topic Adding POIs (speed cameras etc,) to gen 4 SatNav
I'm not going to claim to know what that means or be able to any more help, but thank you facade for the obvious amount of effort you have put into working all that out.
Time to create page: 2.783 seconds
