Jimny 3 Tach/RPM wire
- Jim Jim
21 May 2019 14:26 #208581
by Jim Jim
Replied by Jim Jim on topic Jimny 3 Tach/RPM wire
WOW, thats awesome. I have been lately thinking of doing this. I Was wonder what the stock internals and drive line will handle, compression ratio, if there ECU can be remapped for injected models etc.
Very impressive..., I will PM you.
22 May 2019 21:42 #208762
by Keithy
Replied by Keithy on topic Jimny 3 Tach/RPM wire
The stock internals are it's weakness.....really weak con rods....and the fact I fitted it all to a worn out engine.
Conflicting stories on whether the stock ecu can be remapped.....dunno.
I used Megasquirt and a buddy tried an arduino which looked promising till he blew it up....finally got his working with 30 psi using a Haltech....it was on the 1.5 engine and after a month or 2 it lifted the headgasket.....not good but it was on standard bolts.
I've a thread in the build section......twincharged trayback next.
The following user(s) said Thank You: Jim Jim
- Jim Jim
23 May 2019 12:16 #208796
by Jim Jim
Hi Keithy, I expect the stock internals were made to only have enough strength for whats its intended for.
30PSI is quite a bit of boost, thats great. The head gasket will lift if old, the best ting to do is to have the head checked and resurfaced for flatness, change the head bolts to studs like APR studs and use a performance head gasket if they exist for these engines.
Depending on boost, we ten to use thicker head gaskets to lower the compression ratio of the engine for added boost allowance.
- Jim Jim
23 May 2019 12:19 - 23 May 2019 12:20 #208797
by Jim Jim
I am also looking at doing a 1600cc engine swap with either a Vitara or Baleno engine, both of which we have in abundance here.
From what I have read it seems as though the Vitara engines are easier to swap than the Baleno.
I have to do some more research here regarding that.
I only wanted to boost for some more poop to pass/overtake and for some added torque for towing a small trailer.
Cheers,.
Cheers,.
Last edit: 23 May 2019 12:20 by Jim Jim.
Time to create page: 1.281 seconds
