Re:How do I reset the yellow engine light?
  • Pony
23 May 2019 07:47 #208777 by Pony
thanks for the reply. the charging seems fine, and i changed the battery since i forget the lights couple of times, cold winters etc. i learned that one should replace after some years anyway.
best find a code reader?
  • Pony
23 May 2019 07:48 #208778 by Pony
thanks for the reply. couldn’t figure out - “dico’ing”??
23 May 2019 08:37 #208783 by Lambert
Disconnecting.
  • mickt
23 May 2019 10:34 #208789 by mickt
Replied by mickt on topic Re:How do I reset the yellow engine light?
Max Headroom What made you decide it was a particular sensor that was causing the battery to go flat as I would have thought that once the ignition was off the sensors are OFF?. Or did you get the car ECU read and it gave it the thumbs down or did you just picked that sensor. Even then I doubt that it would cause a battery problem.
Pony your best bet is to get the charging system checked properly and as mentioned get the codes read. Any decent garage will normally read the codes for you as long as it is not a Dealers!
  • Pony
23 May 2019 18:30 #208830 by Pony
thanks, mickt.
i’ll go for the garage.
pony
  • Pony
24 May 2019 12:33 #208870 by Pony
local garage read out the code for free!
sats something like «lambda sensor for preheating in front of catalysator”.
would this be the same that max headroom changed in the manifold?
Time to create page: 2.087 seconds
