Alternator light goes out at circa 3000 rpm but no change in battery voltage
- lohr500
14 Dec 2018 17:21 #198953
by lohr500
Alternator light goes out at circa 3000 rpm but no change in battery voltage was created by lohr500
Hi all, Newbie here, so please be gentle!!
We have a battered old 2004 Jimny which we use around the fields for my kids to learn to drive in.
The battery has stopped charging on the vehicle, but will hold a charge for a few weeks if charged up from a mains charger.
After mains charging the battery initially shows 13.5V and this drops to 12.5v after starting with the engine running.
Now here's the puzzling bit. The battery warning light on the dash is lit before starting and remains lit until around 3000 RPM. Above 3000 it goes out. But with a reliable voltmeter across the battery, I see no increase in voltage at the point when the warning light goes out.
The voltage remains constant at 12.5V. If I probe the main alternator output terminal I get the same voltage.
As the battery holds a charge after mains charging, I am thinking it must be the alternator that is shot, but why would the light go out above 3000RPM with no detectable change in voltage?
I don't want to waste time/money fitting a replacement alternator if this isn't the problem.
The main fuses are all OK and I presume the alternator regulator is built into the alternator and not a separate unit. Is this the case?
Drive belt is nice and tight with no slipping or squealing.
Any ideas. Does it sound like an alternator issue?
- Max Headroom
- Banned
- Thank you received: 217
14 Dec 2018 17:48 #198958
by Max Headroom
Replied by Max Headroom on topic Alternator light goes out at circa 3000 rpm but no change in battery voltage
What happens if you load the system up with lights; heater-fan on max; radio; windscreen wipers on etc etc?
My neighbours car was fine (no warning lights, outputs reading correctly etc) until she had it under load as described above; then the alternator actually tried to stop - the belt squealed like a banshee (and it was a new and correctly adjusted belt).
She replaced the alternator and the problem was instantly fixed
- paradox1001
14 Dec 2018 18:53 #198960
by paradox1001
Replied by paradox1001 on topic Re:Alternator light goes out at circa 3000 rpm but no change in battery voltage
It’s probably the brushes on their last legs or the regulator has gone.
- lohr500
15 Dec 2018 10:20 #198983
by lohr500
Replied by lohr500 on topic Re:Alternator light goes out at circa 3000 rpm but no change in battery voltage
Thanks for the replies.
Loading up the system seems to make no difference.
If it warms up outside a bit today, I'll remove the alternator and investigate further.
- Thank you received: 1888
15 Dec 2018 17:43 #198998
Replied by Lambert on topic Re:Alternator light goes out at circa 3000 rpm but no change in battery voltage
When running the alternator should be giving something in the order of 14v stable across the rev range. A new or reconditioned one sounds to be in your future.
- lohr500
16 Dec 2018 12:36 #199043
by lohr500
Replied by lohr500 on topic Alternator light goes out at circa 3000 rpm but no change in battery voltage
I removed the old unit this morning.
Have ordered a cheapo replacement alternator from eBay today at £53.50 including a special eBay 10% discount valid for yesterday/today only.
UK based seller with delivery supposed to be by Tuesday.
At that price it isn't worth messing round stripping down the old unit to figure out if it can be fixed.
Will report back once the replacement is fitted, but I'm sure it is the root cause of the charging problem.
Time to create page: 0.148 seconds
