Death wobble - wheels, balance and balance again
- Stevie
01 Dec 2018 20:43 #198503
by Stevie
Death wobble - wheels, balance and balance again was created by Stevie
Anyone trying to eliminate death wobble will know that correct wheel balance is a prerequisite before looking at worn components such as king pin bearings, wheel bearings and radius bushes, but it is worth bearing the following in mind.
I recently had my wheels refurbished and new tyres fitted, and at the same time I was doing other things such as new shocks and springs. All this was being done just after buying the vehicle and so I had done very little mileage. I took it out for the inaugural drive only to be hit by death wobble. There was some play in the king pin bearings, so I replaced these, but it made no difference. All the other bushes and ball joints seemed good, although it can be difficult to detect small amounts of wear. Ummm... where next? The first check is always wheel balance, but these had just been done, still, I thought let's start again from scratch. I took them back to the refurbishers and asked for them to be balanced again. Well, unlike the first time where I just picked up the wheels, I was there to see the balancing, or I should say, the attempt to balance them. The problem with the Jimny wheel is the large hole for the hub. While the rear of the wheel will sit against the metal cone on the balancing machine, the rubber thingy that goes up against the face of the Jimny wheel does not want to sit true due to the shape of the wheel. In the end the chap gave up and asked if I could come back another day when his colleague was in. This made me suspicious of how well they were originally balanced. I then went to a local specialist tyre fitter with a good reputation. Initially, they had the same problem mounting the wheel, but then bought out this disc with 5 protruding studs that held the wheel in place by the wheel nut holes.
Anyway, it now drives absolutely perfectly, without a hint of any wobble. Clearly, the wheels were originally balanced based on the wheel not being mounted true on the machine. So, for anyone trying to fix death wobble, don't assume that your newly balanced wheels have been done correctly, otherwise you could spend a lot of time (and possibly money) looking for it elsewhere.
Steve
Steve
01 Dec 2018 21:02 #198504
by Busta
Replied by Busta on topic Death wobble - wheels, balance and balance again
Good wheel balancing is very important, but if it fixes the wobble you probably didn't have death wobble in the first place! Death wobble is a violent oscillation of the wheels that forces you to slow down until it stop.
01 Dec 2018 22:28 #198508
by Scimike
Replied by Scimike on topic Death wobble - wheels, balance and balance again
When I had my wheels refurbished they told me they could not balance them, as you say they did not have the correct fitting for the Jimny wheel hole, but they just told me which is fair enough. I had to take them to a local tyre fitting shop which had equipment and did them no problem for £10, which I thought was good value for the five wheels.
So the Jimny hole can be an issue for some, but they should have owned up..
02 Dec 2018 08:18 - 02 Dec 2018 08:19 #198515
by Bosanek
Replied by Bosanek on topic Death wobble - wheels, balance and balance again
Did you read this comprehensive
wiki article about death wobble
Wheel balancing has a dedicated chapter there, where many aspects of proper wheel balancing are mentioned. I wrote that chapter, and some others too. The concept of proper wheel balancing for Jimny goes far beyond just having a proper seat for the wheel.
That detail about using a properly matching seat for Jimny wheels on a balancing machine is indeed important. I will now add that into the article to explicitly mention that factor (it was presumed that going to a reputable tyre workshop implies that they have proper tools or at least a professional etiquette to admit when they don't).
Last edit: 02 Dec 2018 08:19 by Bosanek.
- Stevie
02 Dec 2018 12:32 #198521
by Stevie
Replied by Stevie on topic Death wobble - wheels, balance and balance again
The equipment often used is like the yellow rubber retainer show here
and, from what I saw, was near impossible to get it to sit true on the face of the Jimny wheels. The tighter it was done up, the worse it got. The second tyre fitters I went to also tried using this method, and then used something like this
To be fair, the original fitter might not have realised that it was not mounted true (doing dozens of wheels the same way every day), and was perfectly balanced for the less than perfect mounting.
Anyway, as Busta said, it wasn't what we know as death wobble, but I just wanted to highlight the issue I came across and not to dismiss wheel balance even though it might have already been done.
Steve
Steve
- Max Headroom
- Banned
- Thank you received: 217
02 Dec 2018 12:52 #198522
by Max Headroom
Replied by Max Headroom on topic Death wobble - wheels, balance and balance again
Superb info - thanks chaps.
Think I'll print these images off and show my tyre fitting workshop next time I get the job done - I have no idea if they used anything like this the first time around!
Time to create page: 0.198 seconds
