Battery terminal size
14 Nov 2018 17:29 #197658
by Scimike
Replied by Scimike on topic Battery terminal size
I personally would not go for any of them in my Jimny as they are a bit pricey for me, but I was forced to pick one I have heard good thing about Optima Red and Yellow top batteries from people with Land Rovers. Dont know the technology behind Optima, but the Excide is just AGM technology (start /stop cars) and a similar capacity AGM is about £120, so dont understand why its more ££££ or why its any better than a normal AGM.
So Yellow top gets my vote but only if someone else is paying.
- auchenblae
- Elite Member
- Thank you received: 25
14 Nov 2018 19:50 #197662
by auchenblae
eddie
24 Swift Ultra ALLGRIP
16 SZ3 gone 25
07 JLX+ gone 16
99 JLX gone 07
Replied by auchenblae on topic Battery terminal size
Stop messing about on the net and getting your knickers in a twist.
Just go to a motor factors, Halfords or whatever and do not try to be clever.
Then physicaly pick a battery that is the correct size and with the correct terminals. Take the old one with you to make sure it is te correct size.
eddie
16 SZ3 gone 25
07 JLX+ gone 16
99 JLX gone 07
The following user(s) said Thank You: Busta
- mickt
14 Nov 2018 20:43 #197663
by mickt
Replied by mickt on topic Battery terminal size
I have used Halfords for all of my battery needs but unfortunately misplaced my trade card. I am awaiting for my local branch to get some in their store and hopefully I will have the savings to see if they have a straight forward battery fit. I do not need to take the old one down as I know the dimensions etc of the one fitted but I would like to keep the car as is as regards the terminals. I am not messing about either as the car is my daughters and her money is as all the youngsters today tight so I want to ensure she gets the best for what she pays! Thanks Jim for the Halfords info and I will check to see if they have stock here in Stoke on Trent. Thanks all for your replies.
15 Nov 2018 13:20 #197679
by facade
Replied by facade on topic Battery terminal size
The 45AH battery that fits the 2001 Jimny with Japanese terminals, the largest that fits the battery tray at 238mm long, is a Varta B33 (330CCA), Yuasa YBX3057 (400CCA)
Put a yuasa on this morning, as it looks like I won't be able to get hold of a new jimny for 2 years or so. The Varta I took off only lasted 8 years, they just don't make modern stuff properly.
I paid £72 at a local factors, Tayna do it for £63 delivered, seen it as low as £55 delivered online.
- mickt
15 Nov 2018 15:29 - 21 Nov 2018 12:39 #197681
by mickt
I have ordered my Yussa YBX5057 from a online supplier for £68.99 delivered. Halfords use their own codes on the batteries and were more expensive for them though.
Last edit: 21 Nov 2018 12:39 by mickt.
15 Nov 2018 18:33 #197690
by facade
I should have sent off for a 5057, but I didn't want to wait around for a courier.
I reckon there are 2 years left in the car,, hopefully there will be some new jimnys in stock by then.
Time to create page: 0.188 seconds
