Clutch Pedal Free Play
02 Oct 2018 16:12 - 02 Oct 2018 16:21 #196441
by Scimike
Stiff was the wrong word to use on my part, but the free play on my Jimny (2009) is not as light as a piano key. If I place my hand on the floor and use only my index finger to press down I can't really move the free play, with an additional finger helping I can move the free play to the point at which the clutch starts to open.
If you look at the pedal box (just looked) it has a big spring to return the clutch pedal to the box stops, this needs to be overcome to feel the free play
Back to adjustment. I believe you can only adjust cable free play from under the vehicle at the clutch end. The pedal hight within the car is a function of stops on the pedal box and should not alter with cable free play adjustment. Not sure the pedal box is designed to allow hight adjustment, but it could be achieved but packing the stop gap with washers etc, its a diy solution.
Replied by Scimike on topic Clutch Pedal Free Play
mickt wrote: Clutch pedals should not be stiff at all.
Last edit: 02 Oct 2018 16:21 by Scimike. Reason: Spotted the big spring in the pedal box which returnes the pedal to the stops.
- komdan
02 Oct 2018 16:55 #196445
by komdan
Replied by komdan on topic Clutch Pedal Free Play
Is your clutch genuine? if yes how many km's you did with that stiff pedal?
02 Oct 2018 17:17 #196447
Replied by Riccy on topic Clutch Pedal Free Play
The only place you can adjust the cable is underneath where it enters the bell housing. There is a black plastic nut to adjust it with. Should be slack basically (i.e. not pulling on the release fork). This can be seen by popping off the cover on the gearbox beside the adjuster:
bigjimny.com/mediawiki/images/1/17/Clutc...e_%28unhooked%29.png
have a look at the wiki for more info on a clutch change:
bigjimny.com/mediawiki/index.php?title=Clutch_replacement
The following user(s) said Thank You: komdan
- komdan
02 Oct 2018 17:53 #196452
by komdan
Yes, I seen it underneath, my question is how can I easily unscrew the bolt without a lift and with which tool/wrench? Stock height jimny..
03 Oct 2018 05:46 #196457
Replied by Riccy on topic Re:Clutch Pedal Free Play
The black adjuster shouldn’t need a tool, maybe just some grips to loosen it. Usually only hand tight.
Unless your a really heavy set person you should be able to get under a standard height jimny without a garage lift.
Ramps would work as well. Perhaps this is a job for a garage. I tend to find people asking basic questions like this usually make things under a car worse when they fiddle. Are you sure about doing this yourself? Obviously, no offence intended!
03 Oct 2018 11:29 #196467
by Busta
Replied by Busta on topic Clutch Pedal Free Play
Sorry, my cable slack example wasn't quite accurate. Free play is when the clutch arm is not putting any pressure on the thrust bearing. There will still be a small amount of tension on the clutch cable. If you have no free play, then clutch springs are not able to exert maximum force on the clutch plates, and you reduce the strength of the clutch. This increases wear on the clutch and can lead to premature failure, or alternatively it gives symptoms that the clutch is worn when it is merely being prevented from engaging fully.
Time to create page: 0.503 seconds
