Extra idler wheel for alternator to stop belt squeal
  • OlaGB
23 Sep 2018 03:59 #196221 by OlaGB
No eBay APP ID and/or Cert ID defined in Kunena configurationYup, i believe this is the one i bought :
23 Sep 2018 04:35 #196222 by zukebob
Thanks. That is the one I was looking at. I'm honestly surprised that it didn't grow at least a noticeable amount in size. As I mentioned, I will be following this with a high level of interest. I will also probably annoy you several months down the road to get some feedback.
  • TomDK
23 Sep 2018 06:22 #196223 by TomDK
Yes it is a bit odd really.
My buddy has a 120A alternator from a land cruiser in his Jimny. And it's much bigger than standard.
  • OlaGB
23 Sep 2018 09:18 #196224 by OlaGB
Yeah, i'm pretty sure we are not looking at 145A capasity, based on both price and size, but i can see an improvement on my volt's while winching.
I can ask them now that ive bought it, and used it for a while, if they can provide a more reliable number..
05 Oct 2018 06:30 #196510 by zukebob
OlaGB. I apologize if it seems like I am using you as a test subject (unfortunately I really am to some degree) but wanted to see if you have had an opportunity to contact the alternator vendor. If they confirm that 145 amps is the rated capacity, I would really like to get some feedback if you have any buildup of heat with the alternator.
Thanks
Bob
06 Oct 2018 09:28 #196528 by facade
It will depend on how they test it.
The standard alternator has a nominal output of 65A @ 13.5V
The Lucas replacement I fitted is rated at 85A (with no provisos, for all I know that is into a dead short).
They should be tested and rated to SAE J 56, which defines the max output as what it gives @ 6000 (alternator) RPM.
It ought to be labelled something like 30/85/13.5 which is idle output/6000RPM output/test voltage.
None of them can give the maximum output for more than a couple of minutes without additional cooling though, they are not designed for it.
The following user(s) said Thank You: zukebob
Time to create page: 0.299 seconds
