Towing a Jimny, is the owners manual wrong?
12 Sep 2018 12:08 #195927
Replied by yakuza on topic Towing a Jimny, is the owners manual wrong?
Byt the way: later models gear boxes have closed bearings with green and blue plastic sides so they wouldn't benefit (much) from the circulating oil for lubrication anyways.
After 2009 or so they came with closed up bearings inside.
But there is also the cooling effect of the circulating oil. Could be that upper bearings in the case would overheat from lack of oil circulating inside..
12 Sep 2018 15:04 #195932
by jimkyx
Replied by jimkyx on topic Re:Towing a Jimny, is the owners manual wrong?
Read some where that when a Jimny was towed long distance behind an RV the chap disconnected the prop shaft --- sounds a bit extreme to me.
Sent from my GT-I9505 using Tapatalk
12 Sep 2018 16:50 #195939
by Busta
It's only 4 bolts, but I agree it would be a nuisance. Easier than changing the gearbox though. Easier still would be to buy a small car trailer to put the Jimny on. Then you can tow it legally without the hassle of an A-frame, connecting up the braking system and not being able to reverse.
Replied by Busta on topic Re:Towing a Jimny, is the owners manual wrong?
jimkyx wrote: Read some where that when a Jimny was towed long distance behind an RV the chap disconnected the prop shaft --- sounds a bit extreme to me.
- Thank you received: 1971
12 Sep 2018 19:21 #195951
Replied by Lambert on topic Re:Towing a Jimny, is the owners manual wrong?
Why did you have to mention A frames?
13 Sep 2018 14:25 #195974
by facade
Replied by facade on topic Re:Towing a Jimny, is the owners manual wrong?
When the crank pulley fell apart on mine, the Nice Man from the AA just used that spectacle thing to lift the back wheels and took me home. I didn't need to say anything, apart from "let me just check we are in 2wd" - you never know, when you are broken down in traffic you might accidentally knock the lever......
The bearings that wear would be the plain bushes inside the gears on the mainshaft, doubt if it would really be a problem for a few miles.
17 Sep 2018 08:29 #196049
by Bosanek
Replied by Bosanek on topic Towing a Jimny, is the owners manual wrong?
I had started
the same kind of topic
a while ago, and yes we came to the conclusion which Busta has nicely explained (input shaft and lubrication talk).
I wrote a wiki article this morning about this entire topic.
If anyone has anything to add (or to correct) there, please do so.
One thing puzzles me though.
I have the user manuals for all but the most recent Jimny revisions, from type 1 from 1999 to type 9 from 2012.
Types 1, 2, 3 and 4 are with lever operated transfer box.
Types 5 and newer are with push button operated transfer box.
The user manuals for all push-button Jimnys (2005+) contain the same restrictive rules for towing.
The first two types (1 from 1999 and type 2 from 2001) have no mentioning of towing a Jimny at all in the user manuals. The entire sub-chapter of towing a Jimny is completely absent from user manuals for those early types 1 and 2.
However, types 3 and 4 (from 2002 and 2004) contain the same restrictive rules as the push-button types (only the pictures in the procedures are different, as you operate 4WD with a lever instead of buttons).
Since types 3 and 4 (should) have the same transfer box and the gear box as type 1 and 2, what the heck could be all that different between them to justify the introduction of those rules for types 3 and 4?
Or could it be that even types 1 and 2 are susceptible to those rules as well, but that Suzuki just had not thought of those issues before 2002?
By the way, when did the R72 gearbox "arrive"? Was is at the same time with the push button transfer box or was it before?
Time to create page: 0.239 seconds
