Canoe on Jimny Bits roof rack/cage
10 Sep 2018 21:47 - 10 Sep 2018 21:52 #195867 by Busta
I can't help with the Jimny Bits rack, but I carry a 16ft canoe on my Jimny on home made stainless steel roof bars that mount direct to the roof bolts. I run an extra strap from the front of the canoe down to the tie down points under the front bumper and it sits very securely. I can still happily cruise at 70mph without any drama.
Before I made my own bars I had this cheap ebay roof tray which wasn't as secure but still did the job.
Last edit: 10 Sep 2018 21:52 by Busta.
  • Eskimo
10 Sep 2018 23:22 - 10 Sep 2018 23:23 #195869 by Eskimo
Replied by Eskimo on topic Canoe on Jimny Bits roof rack/cage
Nice one Busta, I reckon if you put 1 under each side you could probably take the Jim canoeing with you :laugh: :laugh: :laugh:
Last edit: 10 Sep 2018 23:23 by Eskimo.
  • Grainfoot
11 Sep 2018 05:00 #195874 by Grainfoot
Replied by Grainfoot on topic Canoe on Jimny Bits roof rack/cage
Busta wrote: I can't help with the Jimny Bits rack, but I carry a 16ft canoe on my Jimny on home made stainless steel roof bars that mount direct to the roof bolts. I run an extra strap from the front of the canoe down to the tie down points under the front bumper and it sits very securely. I can still happily cruise at 70mph without any drama.
I notice you had strap running though doors around tray rack. Was that for additional fixing.?
Any pics of your stainless bars and fixing. That might be our best option.
11 Sep 2018 07:55 - 11 Sep 2018 08:07 #195880 by Busta
No that's just the loose end of the strap. Shutting it in the door stops it flapping in the wind.
These are the first bars I made up. My current ones are much the same, but shinier. Very simple and strong.
Last edit: 11 Sep 2018 08:07 by Busta.
The following user(s) said Thank You: Grainfoot
  • Grainfoot
11 Sep 2018 08:35 #195883 by Grainfoot
They look ideal. Is there enough height on them so curvature of canoe bow doesn't interfere with windscreen view?
11 Sep 2018 11:56 #195885 by Busta
Well you can certainly see it through the windscreen, but it doesn't hinder my view of the road any more than it does with any other car. My friend carries his on a Volvo V70 and I'd say his view is worse.
Time to create page: 0.588 seconds
