Guide on installing 4WD transmission in a 2WD-only Jimny
- Thank you received: 1889
19 Jul 2018 20:16 #194483
Replied by Lambert on topic Guide on installing 4WD transmission in a 2WD-only Jimny
Yeah. 4x4 to 4x2. In conjunction with the new Quaife helical diff a 4x2 Jimny would still do what bit of off road I need but with a load less unnecessary weight for my preferred "precision" driving helping the handling and the acceleration.
The following user(s) said Thank You: jimkyx
23 Jul 2018 06:58 #194549
Easily spotted with no roof rails and black plastic bumpers, flares and skirts.
However the price and condition of the '99-00 4x4 Jimnys in Norway would suggest that this is not any point in doing.
And the change in front axle weight could be a problem with Norwegian Vegvesen.
To get it approved you would need documentation from Suzuki Norway RSA i think.
Replied by yakuza on topic Guide on installing 4WD transmission in a 2WD-only Jimny
Only one or two came in from Germany on private import i think.MadsV wrote: Good write-up! We have some of these in Norway and they are very cheap
25 Jul 2018 13:57 #194635
by Bosanek
Replied by Bosanek on topic Guide on installing 4WD transmission in a 2WD-only Jimny
I have significantly improved the guide in the meantime, and added some pictures too.
I have just one uncertainty - is there any difference whatsoever between the components in the front wheel hub assembly between ABS and non-ABS equipped Jimnys?
I can see that there is no ABS sensor on the wheel hub on non-ABS equipped Jimnys, but I wonder what are the differences inside the hub assembly if any?
25 Jul 2018 14:00 #194636
by jimkyx
Replied by jimkyx on topic Re:Guide on installing 4WD transmission in a 2WD-only Jimny
Me too. Ditch the front axel and have IFS. Out with the transfer box but not sure how the prop shaft would line up!
Sent from my GT-I9505 using Tapatalk
25 Jul 2018 21:27 #194645
by Busta
The diff is offset, so it wouldn't line up at all.
Replied by Busta on topic Re:Guide on installing 4WD transmission in a 2WD-only Jimny
jimkyx wrote: Me too. Ditch the front axel and have IFS. Out with the transfer box but not sure how the prop shaft would line up!
26 Jul 2018 04:19 - 26 Jul 2018 04:25 #194653
Replied by Lambert on topic Re:Guide on installing 4WD transmission in a 2WD-only Jimny
Having a propshaft offset in 2 directions isn't a problem though. Think of tractor pto drives. That said I would use a propshaft in 2 halves with a carrier bearing to minimise some of the angles on the ends.
Last edit: 26 Jul 2018 04:25 by Lambert.
Time to create page: 0.448 seconds
