Jimny Won't Start PLEASE HELP
20 Dec 2017 21:44 #187694 by Rhinoman
Try checking for codes while cranking
  • Sheppard4x4
03 Jan 2018 09:50 #188000 by Sheppard4x4
Replied by Sheppard4x4 on topic Jimny Won't Start PLEASE HELP
Over Christmas I’ve checked all the fuses and they are all good under the driver’s side and we have tried cranking it over to get the code and it still just flashed 12
I fitted a new crank shaft sensor still the same
And still no spark so I think unless there is any other ideas ?
It is the ECM is faulty.
  • CharlesS
09 Jan 2018 04:41 #188155 by CharlesS
Replied by CharlesS on topic Jimny Won't Start PLEASE HELP
There should be approximately 5VDC at the Crank Position Sensor when the ignition is turned to ON, but not running. You can back probe the wires to see if there is voltage.
IF there is not... then I would suggest you follow the CPS wiring harness back to a major harness connector to see if the connector pins are oxidized (dirty). The lack of voltage to the CPS will stop the engine from starting.
  • Sheppard4x4
09 Jan 2018 12:54 #188163 by Sheppard4x4
THE JIMNY LIVES AGAIN
Hi everyone that helped thank you very much the jimny lives again and it was the black wire had snapped by the crank sensor plug so off for the mot now
Thanks
Sheppard 4X4
