Alternator belt tightening
  • chris1211
12 Dec 2017 22:20 #187395 by chris1211
Alternator belt tightening was created by chris1211
Is this the bolt you unscrew a little bit to adjust the belt tension, the picture is taken upside down any help :)
13 Dec 2017 05:34 #187401 by Lambert
Replied by Lambert on topic Alternator belt tightening
One of them yes. You will need to slack off the other mounting bolt too to allow it to rotate.
  • chris1211
13 Dec 2017 06:22 #187404 by chris1211
Replied by chris1211 on topic Alternator belt tightening
Wheres the other one to
13 Dec 2017 07:24 #187405 by Lambert
If you look closely you can see on the opposite side of the alt that there's a solid mounting point to the block, a pivot about which the adjustment you pictured rotates. Just needs to be a bit slack so the whole alt can move.
  • chris1211
13 Dec 2017 17:14 #187412 by chris1211
Okay cheers will look tomorrow
Time to create page: 1.234 seconds
