4x4 light flashing and 2” body lift
  • X88RED
25 Nov 2017 23:38 #186732 by X88RED
Hello
Just had a 2” body lift fitted and now my 4x4 light is flashing! Previously when it was in 4x4 the light stayed on. Anyone have any idea what could be causing the flashing light?
My Jimny has manual lockers fitted.
Thanks,
Redmond
26 Nov 2017 06:06 #186735 by Lambert
I would be looking at the wires out of the transfer box and making sure they have not been disconnected either intentionally and needing plugging in or unitentionally and snapped off being too tight. Then also check the wiring to the vacuum solenoids even though they are redundant. Something hqs been disturbed by the body lift and needs reconnection.
26 Nov 2017 09:56 #186746 by jackonlyjack
Possibly not related but did you get the transfer stick bent
With the body lift the stick maybe hitting bodywork and not fully engaging in the box
  • X88RED
26 Nov 2017 18:58 #186761 by X88RED
Replied by X88RED on topic 4x4 light flashing and 2” body lift
So had a check over all the wiring today and everything looks ok to me - annoying! not sure what to check next?
I did have the transfer stick bent, but i think it needs to be done a bit more as it seems to not properly go into 4X4L and its easily pushed out
  • X88RED
28 Nov 2017 16:57 #186821 by X88RED
So can someone please explain to me what happens to the vacuum system when manual locking hubs are fitted? How are the hubs fitted exactly? Everything I read points to a leak in the vacuum system if the 4wd light flashes but my system is not in use?
28 Nov 2017 17:29 #186823 by Lambert
All i did was blank off the flex pipes up by the solenoids in both direction to keep the vacuum intact and also any junk getting in. Then just a mechanical swap of the hubs.dead easy.
Time to create page: 2.526 seconds
