4WD not engaging, indicator light illuminating.
- Mraz
15 Jan 2018 17:58 #188411
by Mraz
Replied by Mraz on topic 4WD not engaging, indicator light illuminating.
Hubs do "clack clack" and transfer box does "wuuut"
When in 4WD lift front wheels and go under the car. Try if you can move/spin front driveshaft. If you can spin it than transfer box is not engaging. If you can spin it and wheels start to move then transfer box is not engaging but hubs are. If you can't spin the front driveshaft but can spin the wheels than transfer box is engaging but hubs are not.
17 Jan 2018 13:18 #188478
by bryn
Replied by bryn on topic 4WD not engaging, indicator light illuminating.
I think I’ve managed to narrow it down to the vacuum system by using the fault finding section on the forum and its an intermittent fault as well just to complicate things. I have;
1, Jacked each wheel up in turn separately , selected 4x4 (light is on) and when in fault I can spin the wheel.
2, Taken of the hubs and checked the teethed collars (clicked them in to place and un clicked them) which are fine and resealed the hubs when back on.
3, Checked the vacuum pipe work for the obvious and cleaned the small air filter.
4, Checked all the connections to the axil/wheel housing.
When it does work I hear a wurr and double click the last click being the vacuum hubs engaging. When not working I don’t hear the final click of the hubs engaging.
Can anyone give me a few pointers and.................................I live in the Wetherby area and does anyone know a good 4x4 mechanic.
Appreciated bryn
Appreciated bryn
- Thank you received: 1889
17 Jan 2018 13:30 #188480
Replied by Lambert on topic 4WD not engaging, indicator light illuminating.
Not a good 4x4 specialist but i am only in Harrogate if you want a second set of eyes on it?
- florinelu07
17 Jan 2018 13:46 #188481
by florinelu07
Replied by florinelu07 on topic 4WD not engaging, indicator light illuminating.
Have you checked the vacuum valves? these are quite easy to clean an lube with WD40.
Also the locking hubs should not have any grease in excess or improper seal on the wheel hubs.
If you have access to a manual vacuum pump or a seringe, you can manually lock/unlock each hub via a hose and start from the wheels and move to the vacuum lines and valves to check where is the leakage.
I'm thinking also in fitting a vaccum probe on the sistem to have a live measurement of the pressure (negative) within the circuit, but still no feasible (I mean cheap
) is available.
17 Jan 2018 19:53 #188499
by bryn
Can you point me in that direction please and tips.
Once again thanks
bryn
Once again thanks
bryn
17 Jan 2018 20:09 - 17 Jan 2018 20:10 #188500
Replied by Daniel30 on topic 4WD not engaging, indicator light illuminating.
Last edit: 17 Jan 2018 20:10 by Daniel30.
Time to create page: 0.148 seconds
