Steering wheel and honker
  • petejones69
14 Nov 2017 20:19 #186263 by petejones69
Steering wheel and honker was created by petejones69
I'm going to replace the steering wheel with one from Raptor 4x4. What happens about the buttons for the horn? Do I just pop a new button somewhere and use that?
Also, I assume it's OK to ditch the airbag? They aren't legal requirements are they?
Cheers
Pete
14 Nov 2017 20:34 #186264 by jackonlyjack
I think air bags are mandatory
and Raptor 4x4 you must have money to burn lol
steering boss look on ebay
The following user(s) said Thank You: petejones69
  • petejones69
14 Nov 2017 21:04 #186265 by petejones69
Replied by petejones69 on topic Steering wheel and honker
The steering wheel is only £40, agree with you on the steering wheel boss though!
14 Nov 2017 21:27 #186266 by jackonlyjack
If you're going to fit a wheel i would suggest buying the boss first
because wheels come in three forms flat,semi dish and dished
so you can decide once you have the boss how much closer you need the wheel to you
Jack
15 Nov 2017 05:09 #186268 by Lambert
Replied by Lambert on topic Steering wheel and honker
If you remove the wheel airbag then you will need to disable the entire system. It is part of the mot that the srs warning light comes on and then extinguishes after a self diagnostic. I guess that if you have removed the wheel bag and converted the passenger bag into a cubby hole it is possible that the tester will accept that no srs system is in place and therefore the absence of a warning on the dashboard shouldn't be a problem. Inform your insurer too as disabled safety systems will definitely attract the attention of a loss adjuster in the event of a claim. Personally I wouldn't bother with a new wheel if it's a road car, though if it's being trailered to quarries etc then crack on and don't worry about it.
15 Nov 2017 11:57 #186277 by jackonlyjack
Some kits come with a 1k resistor to trick the system
Do a little search ;)
Time to create page: 2.557 seconds
