Which clutch do you use and why?
- Millen
21 Oct 2017 10:02 #185394
by Millen
Which clutch do you use and why? was created by Millen
Hi y'all!
I wonder which type/model of clutch you use in your Jimny, how it works for you and why you have chosen the one you got (If you did)?
Clutch is slipping, so I need to decide what to chose.
22 Oct 2017 07:18 #185408
Replied by yakuza on topic Which clutch do you use and why?
Lucas, the cheapest one i could find with a recognizable name on it.. complete clutch kit bought from mister-auto.
Slight vibration around 2000rpm like others have reported after changing clutch. It has three springs but original has 4. some have six. i would buy a better one next time, and with four springs to see if vibratoins go away.. It slips a bit if i drive offroad with too heavy throttle with my m16a but isn't smelly going uphill on highway like my old one was.
It would be ok if you are on a budget and don't go too much offroading and have m13a engine i guess.
The following user(s) said Thank You: Millen
- Millen
22 Oct 2017 07:53 #185409
by Millen
Replied by Millen on topic Which clutch do you use and why?
Sorry to hear about the vibrations, could it have been something wrong with the clutch from start?
Do you mean people get those vibrations after changing to that specific model of clutch or just any model?
My own plans are kind of unsure but I have thought about raising it 2-3" with other suspension and what goes with such modification.
Putting bigger tyres on it, change the gear ration in low and possibly get other unlockable diffs.
A little bit of turbo boost would be fun but we will see where it goes, at least it's going to gnarly offroad terrain and I will most likely need a bit of extra clearance under the car.
23 Oct 2017 08:32 - 23 Oct 2017 08:34 #185443
My theory is that the three springs difference to the original four springs makes the vibrations due to a change in the mass of the clutch plate.
Other users have reported to get these 2000rpm vibrations when using cheap clutches.
I would go for a clutch similar to the original one with four springs with what i know now..
There is also stronger aftermarket clutches you should choose if you plan on bigger wheels and stronger engine.
edit: 2000rpm vibrations have decreased in the time passed since i changed the clutch though..
Millen wrote: Sorry to hear about the vibrations, could it have been something wrong with the clutch from start?
Last edit: 23 Oct 2017 08:34 by yakuza.
- Millen
23 Oct 2017 09:46 - 23 Oct 2017 11:54 #185446
by Millen
I see ...
There is the Excedy Safari version with more clamp pressure and some other features in the BJ shop, more to read about them on the Excedy webpage.
Then there will be different ones with pucks an such, some with metal and carbon mixes.
Have not seen any full faced carbon/metal mixed clutch like the Spec Stage 3+ yet.
Is it recommended to replace the clutch cable to while at it?
Clutch pedal has felt a bit heavy and the pedal has also had a very short distance of slip to bite, but it might just be because of how it's contructed and/or the wear of the clutch.
Best Regards
Mattias
Best Regards
Mattias
Last edit: 23 Oct 2017 11:54 by Millen.
