strange noise.
22 Aug 2017 20:40 #183563
by kirkynut
Replied by kirkynut on topic strange noise.
Give your radius arm bolts a little nip up and see if that solves it.
The following user(s) said Thank You: 1066Boy
- 1066Boy
23 Aug 2017 17:59 #183583
by 1066Boy
Replied by 1066Boy on topic strange noise.
Thinking about it today, I fitted a front diff guard a few months back, the type that bolts one side to the radius arm mount. If its not tight enough the noise would probly be amplified by the big lump of steel clamped to the diff.
23 Aug 2017 18:09 #183587
Replied by Riccy on topic strange noise.
Thats a good call actually...
Mine makes similar creaky noises sometimes (but it makes so many other noises its hard to tell!) I have a JB diff guard also, and creaking started after that i think. Doesnt happen unless REALLY offroading tho. My radius arms are KAP with superpro bushes, so should be good. bolts are not mega tight as most use locknuts so i wanted them to be flexible a wee bit.
- 1066Boy
24 Aug 2017 16:22 #183624
by 1066Boy
You were spot on. drivers side rear bolt of the two was not loose but I was able to get a complete turn on it.
Did it lunchtime and it was all quiet on the way home. Fingers crossed its as simple as that. Thanks for the idea.
kirkynut wrote: Give your radius arm bolts a little nip up and see if that solves it.
Time to create page: 1.495 seconds
