new jimny owner, fuel gauge issues and a few other questions
- whitfield
14 Jun 2017 17:01 #182020
by whitfield
new jimny owner, fuel gauge issues and a few other questions was created by whitfield
Hi, just registered.
I have just bought my wife a jimny for her first car. It has a few issues but nothing major. Its a 1999 1.3.
It had a missfire that was flashing the engine light but I seem to have fixed that.
It has a hole in the boot floor where the jack goes but as I just spent 6 months making panels and welding them into my old bedford im not worried about that.
What is annoying me if the fuel fauge. Should it go back to zero when the ignition is turned off? It doesnt. I put some fuel in and tha gauge seemed to do something but its hard to tell. Its stuck just under half way.
Do the gauges fail? Fixable? How do I get the dash cluster out to check, do I have to remove the whole dashboard?
Could it be the sender? How do you get to it?
Things would be alot easier with a manual but I cant find one.
I have 2 clocks, neither work. Wiring all checks out. Are they a common failure?
It has a bit of bumpsteer but there is loads of info on here about that kind of thing so we can ignore that for now.
The steering wheel foam has detached from the metal inner. what year wheels will interchange? 2 horn buttons if that matters. Common fault?
Its also missing the plastic trim to the rear end of the passenger roof bar, cant seem to find another. The roof bars look to have changed a couple of times, again, what years am I looking for?
Apart from that, a little rear engine oil leak and a couple of coolant weeps its fine.
I was concerned about its suitability as a first car but its soooo easy to drive/manouver/park im sure she will be fine.
14 Jun 2017 19:12 #182022
by Keithy
Replied by Keithy on topic new jimny owner, fuel gauge issues and a few other questions
Fuel guage reads the level when switched off...so that's normal.
You have 2 clocks? I have one...below the radio.....or do you mean the binnacle?
The tool well is available as a repair panel from jimnybits.....saves time.
Jimny is a fine first car.....have fun!
14 Jun 2017 19:18 #182023
by Jezz
It's been fettled just a tad.
Replied by Jezz on topic new jimny owner, fuel gauge issues and a few other questions
My Spanish built soft top's fuel gauge goes back to zero/empty when the ignition is switched off.
- whitfield
14 Jun 2017 19:28 #182025
by whitfield
Replied by whitfield on topic new jimny owner, fuel gauge issues and a few other questions
Ok, so one vote for fuel gauge should go to zero and one vote it reads fuel level even with ignition off.
The car is at a friends yard and will stay there untill it is given to my wife as a surprise when she passes.
Unfortunately this means I cant drive it around to see how the fuel gauge reacts over a period of time.
- whitfield
14 Jun 2017 19:32 #182026
by whitfield
Oh, by 2 clocks I mean one in the dash that doesnt work and one in the glovebox which came with it that also doesn't work. As I say, wiring checks out and no obvious circuit board issues when I took the clocks apart.
Minor issue but would be nice to fix one day.
I saw the jack area panel, £90 ish! Not much less than the whole boot floor.
No ta, ill make the panel myself.
- Thank you received: 683
14 Jun 2017 20:12 #182028
Replied by jackonlyjack on topic new jimny owner, fuel gauge issues and a few other questions
My 04 tin top fuel gauge shows level with ignition off
Jack
Jack
Time to create page: 0.577 seconds
