Fan clutch replacement 2006 VVT - how to?
07 May 2017 11:46 - 07 May 2017 11:48 #180989 by asypeer
Hi all, the former owner's mechanic thought it a good idea to bolt the fan clutch (probably to prevent overheating)
Now the fan clutch spins all the time - even when the engine is cold which is noisy and fuel consuming.
I got a used but pretty new fan clutch with the fan and I'm interested to remove the old ones and replace them.
Was looking for the procedure in the FSM but could not find any steps.
Can someone give some tips? What should be removed? I don't want remove the radiator if not needed..
Thanks!!
Last edit: 07 May 2017 11:48 by asypeer.
07 May 2017 11:55 #180990 by j999pre
Remove the top 2 10mm bolts holding the rad to the uprights. Tilt it forward. Unbolt fan. Lift clear then reverse to refit
Grey pick up Jimny
07 May 2017 12:04 #180992 by asypeer
Thanks buddy! No need to lock the pulley or loosen any belts?
Is it that simple?
Time to create page: 2.812 seconds
