Strange Noise....clutch related?
  • ryan28
21 Apr 2017 14:20 #180456 by ryan28
Strange Noise....clutch related? was created by ryan28
The Jimny has been making some funky noises when engaging reverse.
It's like a whining noise and you get no drive in reverse. It goes away if you depress the clutch and take it out of gear though....is this clutch related?
The release bearing has been noisy since I got it and the clutch may be on its way out, although it doesn't slip in any gears at all.
Is this a buggered clutch or something else?
Video of the noise here:
1drv.ms/v/s!AorPDvXNE9W9hNQTXap0iuH6ZXoH2Q
21 Apr 2017 19:32 #180457 by Keithy
Sounds like it's not fully in mesh.
22 Apr 2017 09:56 #180476 by Busta
If there was a problem with the clutch it would affect all gears. Sounds like a gearbox issue.
A noisy release bearing isn't unusual. If the clutch isn't slipping then what makes you think it's on its way out?
  • ryan28
22 Apr 2017 18:10 #180489 by ryan28
Replied by ryan28 on topic Strange Noise....clutch related?
Just a high bite point and it's done 70k on the current one really.
What you say makes sense though, sounds like it could well be the gearbox...
  • ryan28
25 Apr 2017 12:14 #180550 by ryan28
It did it in first as well this morning! I'm thinking if may be the clutch after all if it does it in first as well as reverse?
  • ryan28
04 May 2017 17:46 #180906 by ryan28
Ok managed to get a better video of the behavior.
Wife was listening to the engine bay and thought it was coming from the power steering pulley but that could be a red herring as I can't explain why engaging reverse causes it.
Help!.
Time to create page: 2.247 seconds
