advice on roof hole
12 Mar 2017 20:58 #179130 by Scot The Sniper
hi guys im about to put a 52mm hole in the roof of the jimny for a t-bar and lightforce light. my question is there seems to be a raised bit in the middle of the roof and im dont think its gonna fit on there as you need to drill 4 other holes to bolt the t-bar onto the roof so if i drilled 52mm hole in the middle it would probably let in water. has anyone on here done this to there's and if yes where did you drill the 52mm hole in the roof.
cheers
scot
12 Mar 2017 21:20 #179134 by jackonlyjack
Replied by jackonlyjack on topic advice on roof hole
look at the liner inside
looking at the plastic press stud type things across the middle
just take into account the metal they fix into is around 3 inches wide
Jack
Time to create page: 0.922 seconds
