Stopping 4wd flashing light when swapping from electric transfer box to manual
- ZukracerV6
04 Mar 2017 13:39 #178814
by ZukracerV6
Stopping 4wd flashing light when swapping from electric transfer box to manual was created by ZukracerV6
As part of the conversion and modification of the Jimny transfer case to give it the extra power off take, the electric shifter mechanism has been removed and converted to a manual shifter on the transfer case. Therefore, all of the electrics for the both the transfer case and vacuum system is no longer used. I’ve done the mod to fool the system on the vacuum hubs but what needs to be done to the transfer case wiring?
I basically just want to fool the Jimny into thinking it’s only every running in 2WD. Part of the extra power take off conversion, now uses separate lights to indicate what the transfer case is set too etc.
Done some searching but come up blank!
04 Mar 2017 14:52 #178815
Replied by Riccy on topic Stopping 4wd flashing light when swapping from electric transfer box to manual
i think i have a ossible answer for you. i encountered this when changing transfer box's...
down near the bottom of page 2...
www.bigjimny.com/index.php/forum?view=to...=7&id=11993&start=12
- johan65
04 Mar 2017 15:17 - 04 Mar 2017 15:18 #178816
by johan65
Replied by johan65 on topic Re:Stopping 4wd flashing light when swapping from electric transfer box to manual
Maybe this can help guide to possible solution
Last edit: 04 Mar 2017 15:18 by johan65.
Time to create page: 0.317 seconds
