What is this connector/wiring loom?
  • ZukracerV6
20 Feb 2017 23:23 #178308 by ZukracerV6
What is this connector/wiring loom? was created by ZukracerV6
I'm baffled with this connector! The wiring loom was removed from the donor 59 plate Jimny with air con. I had labelled all the connectors but for some reason I've missed this one or the label fell off! Its a 2 wire naturel coloured connector that was on the same section of the wiring loom that runs to the passenger side front head light. I've scoured the Jimny technical manual and cannot find any mention or description of this connector. I thought it may have been for the head light levellers but that is 3 wire connector and the wires are completely different colours.
The 2 wire are light green and black. Both have silver marks/dots running along them.
Do you recognise this part of the wiring loom?
Cheers!
  • Daniel30
20 Feb 2017 23:29 #178309 by Daniel30
Replied by Daniel30 on topic What is this connector/wiring loom?
Fog lights ??
  • ZukracerV6
20 Feb 2017 23:41 #178310 by ZukracerV6
Replied by ZukracerV6 on topic What is this connector/wiring loom?
Daniel30 wrote: Fog lights ??
I think you could be right, the Jimny was fitted with factory fogs and the position of the connector on the wiring loom would be right for the fog lights. Completetly forgot about them! I've accounted for every other wire and connecter with the exception of this one and literally there has been hundreds of them!
Will do a simple test tomorrow and let you know!
Cheers!
  • Daniel30
20 Feb 2017 23:48 #178312 by Daniel30
Looks familiar from when I disconnect mine to chop my bumper ;)
  • Young Pretender
21 Feb 2017 13:42 #178322 by Young Pretender
Replied by Young Pretender on topic What is this connector/wiring loom?
Also looks a bit like the connector that goes into what I think is the windscreen washer motor on the back right of the engine bay. This one has a rubber cover over it but looks the same underneath?
  • Young Pretender
21 Feb 2017 13:47 #178323 by Young Pretender
Or is that a wiper motor (not sure)?
Time to create page: 0.221 seconds
