Death Wobble solve: PROPER wheel balancing is the key!
08 Feb 2017 01:29 #177849 by kirkynut
Balancing beads. That's all I have to say.
08 Feb 2017 05:04 #177850 by Lambert
This is odd as I have my wheels hubcentrically balanced and have no issues with wobble. Ok I have a damper but the last kingpin I replaced I could still feel it wobble even though there was no movement in the hub just a little bit of excess oil on the swivel. I do have alloys though that will take the cone on a balance machine?
  • wilku
08 Feb 2017 08:42 #177851 by wilku
You can just remove the damper for a test drive and see if Death Wobble appears. If it does it means you hide the symptoms with the damper, but the problem remains unsolved. Then I'd consider a proper balancing - otherwise it might be just an unnecessary expense.
08 Feb 2017 13:14 #177862 by Lambert
The ONLY reason I have the damper is because I like how it makes the car feel heavier on the road, which having come from a defender as my last car is what I am used to, without is the car feels light and a bit too twitchy especially in high winds. I definitely don't have any speed related wobble with or without the damper.
  • wilku
08 Feb 2017 14:48 #177863 by wilku
Then you don't have to bother with wheel balancing as much as I had to... Now, that I have it solved a steering damper is next on my list got one already - need to manufacture the brackets now... or find some cheap car part that would do the job ;)
08 Feb 2017 18:21 #177872 by facade
11/60 wrote: This is odd as I have my wheels hubcentrically balanced and have no issues with wobble. Ok I have a damper but the last kingpin I replaced I could still feel it wobble even though there was no movement in the hub just a little bit of excess oil on the swivel. I do have alloys though that will take the cone on a balance machine?
I've not seen Jimny alloys, but usually, alloys are located central by a ring on the hub engaging in the machined central bore, the nuts/bolts just keep them on, so they are balanced with a cone. The later Jimnys I think have this ring as the hole in the early brake discs is smaller than the later ones.
The steel wheels are located by the nuts and should be balanced attached to the flange on the machine (which lives in the "Box of Other Bits" and is a 5 minute job to swap onto the machine)
Time to create page: 0.250 seconds
