2000 Jimny Auto - Seized/Sticking N/S/F Brake Caliper
  • JimnyMax
24 Sep 2016 10:23 #172769 by JimnyMax
Good morning,
It seems the Jimny has got a N/S/F Brake Caliper problem, looks like its sticking. I jacked it up and that side wheel was difficult to turn compared to the other. It's a 2000 Auto.
I've not been driving it much lately due to having a company vehicle, probably once a week. It's mostly left in 'P' Park with no handbrake engaged, could this be the issue? Also recently had the Brake Pads changed.
Please advise on the best thing to do, I've seen repair kits online, Calipers from a broken Jimny as well as a whole new Caliper but unsure of the route to take.
Thank you.
24 Sep 2016 11:12 #172772 by kirkynut
Personally I would replace both front calipers if you are sure it's not just the sliders needing freeing off as they seize too.
The following user(s) said Thank You: JimnyMax
  • JimnyMax
25 Sep 2016 03:47 #172811 by JimnyMax
Cheers man, I'll have a look at those too.
25 Sep 2016 05:05 #172814 by Lambert
Freeing calipers is not a bad job to do if you are confident working on the most safety critical aspect of the car, if not then you will need a competent mechanic.
  • JimnyMax
30 Sep 2016 02:57 #173019 by JimnyMax
Took the Jimny to Cam Suzuki to have the caliper done on Monday, it was a seized caliper in the end so had it replaced. Took 4 days though, but the main thing is it's done.
Thanks for the pointers. :-)
Time to create page: 1.023 seconds
