significant diference 215 75 to 235 75??
  • fransolis94
18 Sep 2016 19:17 #172535 by fransolis94
significant diference 215 75 to 235 75?? was created by fransolis94
hi guys! currently my 2011 jimny has 215 75 15MT tires, but i was thinking on getting the 235 75 15MT tires? will the diference in lost of powe and fuel comsuption will be significant? i have been reading and there a lot of jimnys in here with 235 75 :) thanks!!
18 Sep 2016 20:06 - 18 Sep 2016 20:13 #172543 by kirkynut
The total diameter of a 215/75/15 tyre is 703.5mm.
The total diameter of a 235/75/15 tyre is 733.5mm.
So a difference of 30mm. Which doesn't sound like much but is when you consider an inch is 25.4mm!
It needs a 3" lift really and this is the theoretical diameter too. Add the extra tread of a mud terrain or the massive tread of an extreme mud terrain and it's much bigger than this.
You'll notice quite a loss of torque and power and fuel consumption will be worse. You really could do with a Rocklobster transfer box to bring the high ratios back to where they should be. Low range isn't low enough with 235/75/15's and you'll burn your clutch out off road without a Rocklobster.
Last edit: 18 Sep 2016 20:13 by kirkynut.
  • fransolis94
18 Sep 2016 22:49 #172550 by fransolis94
Replied by fransolis94 on topic significant diference 215 75 to 235 75??
ohhh no so its no a very good idea :( i was just asking because a saw so many jimnys with 235 75, and in my country a cant find 215 80 15 :(
19 Sep 2016 05:27 #172557 by kirkynut
215/80/15's are available from Malatesta tyres. Can you not get them?
They're remoulds though.
  • fransolis94
19 Sep 2016 15:09 #172581 by fransolis94
no i think they dont have them in Costa Rica :(
19 Sep 2016 21:13 #172595 by kirkynut
What about Insa Turbo tyres? They do a few 215/80/15's.
