Crank shaft sensor location
30 Sep 2016 21:09 #173046 by Rhinoman
If you have access to left-handed drill bits then I would suggest using them - the bolt may wind itself out as you drill. A good soaking with plus-gas or similar for a few days will also help.
01 Oct 2016 17:50 #173051 by Me and my Jimny
Hi Fellas
So the araldite didn't hold the bolt onto the block very well, so after running it without anything holding the sensor, as it's a very positive fit anyway, I decided to put a little araldite in the bolt hole to bond it the broken bolt.
I know that might seem a bit permanent but I'm sure if I need to change it again this stuff will free up with a tap, otherwise it is machinable. The Jimny runs fine again now though so hopefully that's one issue behind us.
Cheers
Time to create page: 0.642 seconds
